brownslock
Feb 01, 2022Follower
Confused about best router for my company
Currently we are a small company with less than 20 employees. We use an older NETGEAR ProSafe, Gigabit Dual WAN SSL VPN Firewall, model FVS336Gv2. We want to upgrade to a fster business wireless + wired router. Internally we upgraded our wiring to 10G.
What router would you recommend?
Something you might want to post here in the Business section as this is a Home class router forum:
https://community.netgear.com/t5/Hardware-VPN-Firewalls-and/bd-p/business-vpn-firewalls
- Geoff-NZApprentice
I would definitely upgrade the FVS336Gv2, it went EOL 5 years ago, so you're 5 years behind security updates.
Upgrading your router depends a bit on what features and capability you want. Netgear's business VPN routers were the BR500, then the BR200, however, both are currently EOL. I believe Netgear will announce a new model in the near future, however, what that is and when that will be I do not know.
