diegobaccino
Feb 17, 2017Aspirant
DHCP relay over VPN tunnel to Azure
Hi all,
This is my current set up. I only have one physical (host) server (192.168.0.0/24) and a direct tunnel an Azure VM (192.168.3.0/24), serving as my secondary AD server, DNS, and DHCP. Ho...
DaneA
Feb 20, 2017NETGEAR Employee Retired
Hi diegobaccino,
Welcome to the community! :)
Let me share this old forum thread here since its similar to your concern and it might help.
DaneA
NETGEAR Community Team
- DaneAFeb 23, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to access the old forum thread I've shared and used it as your guide about your concern? If yes, any updates?
DaneA
- diegobaccinoFeb 23, 2017Aspirant
No. The solution on the other thread is not an acceptable solution. I want to know if the Netgear router can support DHCP relay for site-to-site VPNs.
D.
- DaneAFeb 28, 2017NETGEAR Employee Retired
I'm afraid that it is not supported on the FVS336Gv3.
DaneA
- JohnRoMar 03, 2017NETGEAR Employee Retired
Hi diegobaccino,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
