diegobaccino
Feb 17, 2017Aspirant
DHCP relay over VPN tunnel to Azure
Hi all,
This is my current set up. I only have one physical (host) server (192.168.0.0/24) and a direct tunnel an Azure VM (192.168.3.0/24), serving as my secondary AD server, DNS, and DHCP. Ho...
DaneA
Feb 23, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to access the old forum thread I've shared and used it as your guide about your concern? If yes, any updates?
DaneA
NETGEAR Community Team
diegobaccino
Feb 23, 2017Aspirant
No. The solution on the other thread is not an acceptable solution. I want to know if the Netgear router can support DHCP relay for site-to-site VPNs.
D.
- DaneAFeb 28, 2017NETGEAR Employee Retired
I'm afraid that it is not supported on the FVS336Gv3.
DaneA
