diegobaccino
Feb 17, 2017Aspirant
DHCP relay over VPN tunnel to Azure
Hi all,
This is my current set up. I only have one physical (host) server (192.168.0.0/24) and a direct tunnel an Azure VM (192.168.3.0/24), serving as my secondary AD server, DNS, and DHCP. Ho...
dt987
Jul 11, 2017Aspirant
Hi All,
I'm currently using UDP DHCP relay on M4300-52G-PoE+ switch to point to a DHCP server in our network per VLAN interfcae, server itself is Windows 2012R2 VM. DHCP works perfectly fine.
Now, let's say I want to add another DHCP server for redundancy. Does anyone know if it is possible to have primary and secondary UDP DHCP relays? It seems I can add another entry for relay with a different DHCP server IP address, but it's not clear how it will prioritize (or load balance) DHCP requests between servers? I guess the goal is to use one DHCP server as primary and another one as a backup in case if primary is not responding.
Both Windows DHCP server will be setup in failover.
Thanks!
Dmytro
