ngc4
Jun 21, 2016Follower
DHCP Server Range Not Large Enough
Although the DHCP server built into this firewall allows subnets with a /16 mask (255.255.0.0). The DHCP service will not allow a Range of addresses much larger than 300 clients. Are there any updat...
DaneA
Jun 21, 2016NETGEAR Employee Retired
Hi ngc4,
Welcome to the community! :)
Kindly answer the questions below:
a. What is the current firmware version of the SRX5308?
b. Have you tried to perform a factory reset to your SRX5308 then reconfigure it from scratch and check if same problem occurs?
DaneA
NETGEAR Community Team
