ssawyer
Oct 13, 2012Follower
Easy Fix for Intermittent Connections, Slowdowns, Timeouts - DNS related, SRX5308
I'm documenting this here, because I didn't see anything about it in my forum searches, and I believe that it's likely to be a common problem with an easy fix. I had just installed a new Netgear SR...
MPN
Nov 19, 2012Aspirant
This solved our problem as well. Our FVS318N kept having DNS problems, but when I switched to our FVS336G, no problems. Tried different firmware versions and a different FVS318N, nothing helped.
Turns out, the FVS318N has "Block UPD flood" on be default and the FVS336G has it off by default. No problems now.
