ssawyer
Oct 13, 2012Follower
Easy Fix for Intermittent Connections, Slowdowns, Timeouts - DNS related, SRX5308
I'm documenting this here, because I didn't see anything about it in my forum searches, and I believe that it's likely to be a common problem with an easy fix. I had just installed a new Netgear SR...
giusiof
Jan 03, 2013Aspirant
Hi,
unfortunately this solved only some problems.
I updated to Firmware 4.2.1-2 and I'm experiencing intermittent connections yet.
I disabled any type of log on security and udp flood on attack checks , so this is the result
Thu Jan 3 18:14:31 2013(TZi-) [SRX5308][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
<4
Thu Jan 3 18:11:26 2013(TZi-) [SRX5308][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
<4
Thu Jan 3 18:11:21 2013(TZi-) [SRX5308][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
<4
Anyone has this problem?
Thanks
<4
<4
<4
Thanks
