ssawyer
Oct 13, 2012Follower
Easy Fix for Intermittent Connections, Slowdowns, Timeouts - DNS related, SRX5308
I'm documenting this here, because I didn't see anything about it in my forum searches, and I believe that it's likely to be a common problem with an easy fix. I had just installed a new Netgear SR...
BeerDrinker
Apr 25, 2013Aspirant
I see the new firmware has implemented a suggestion from the first post, (b) make the number of simultaneous UDP connections configurable overall. At leats that's what I think the box next to the check box, with a default value of 25 seems to be.
