zeppelinux
Jun 21, 2017Aspirant
Enable IPSec UDP ports for all hosts behind firewall
Hi All, I'm trying to make the IPSec working in hybrid environment (home network/cloud), here is the original problem: https://forums.rancher.com/t/hybrid-cloud-home-network/6646/3 I up...
JohnC_V
Jun 24, 2017NETGEAR Employee Retired
Hi zeppelinux,
Welcome to our community!
Please help us understand the problem that you were having. Are you trying to make the firewall as the VPN server or the firewall will just work as a passthrough? If the firewall will work as a passthrough, the IPsec VPN tunnel is enabled by default. But if it seems that one of the tunnels that you have is working then I don't see any issues from the firewall as it is working by design. No configurations needed if it will work as passthrough.
zeppelinux
Jun 26, 2017Aspirant
Hi John,
Thanks for reply! I'm trying to use the Rancher for managing Docker containers running on my home network and in the cloud (Hubrid network). Rancher connects all the hosts (that supposed to run managed containers) by creating Network overlay (IPSec agent is deployed and running on each host). One of the requirements for this Network Overlay to be functional is to make sure all the 500 and 4500 UDP ports traffic is flowing between ALL participating hosts.
When there is no NAT - everything is working perfcetly and seems like NAT makes this use case invalid i.e. acoring to the response in the Rancher forum there is no way this can work :(
Cheers,
Dmitry
