Golgotha
May 22, 2017Aspirant
ERROR: invalid ID payload. on SRX5308 with firmware 4.3.5.3
since I'v upgrades firmware to 4.3.5.3 IPSEC VPN dont work ... no change made on SRX an client any body have an idea ? Client log : 20170522 10:39:42:029 Default (SA MIG2009-P1) SEND phase ...
- Jun 09, 2017
OK I will try to add a new VPN, but I can't delete existing VPN used by others pepoles
DaneA
Jun 04, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to try to delete the existing IKE / VPN policies then use the VPN Wizard to setup a client-to-box VPN? Also, were you able to access the articles I've shared and use it as reference guides? If yes, what is the result?
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
