MCFH1
May 17, 2017Tutor
FS336Gv3 IPv6 Implemementation Issues
I thought I should post with an update on around 12 months of discussion with Netgear Support and my ISP (Zen Internet).
The FVS336Gv3 router implements IPv6 with a dual session approach not a dual stack approach (which implies a shared PPPoE session). This requires that your ISP support two concurrent sessions which is not a supported scenario with ISPs. ISPs are implementing TR-187 as defined by the broadband forum (https://www.broadband-forum.org/technical/download/TR-187.pdf) - in particular Section 5.1.1
Single PPP dual stack IPv4/IPv6 Session
In the case of a dual-stack session, the mechanism adopted to provide IPv4 and IPv6 connectivity to the customer is based on the architecture described in RFC 4241 [18]. It combines the use of the PPP protocol for the session establishment and the use of DHCPv6 and DHCPv6 Prefix Delegation for the configuration of the IPv6 prefixes, addresses and specific parameters. A single PPP session is used to carry both IPv4 and IPv6 traffic; the device that initiates the PPP session will get both an IPv4 address and at least one IPv6 prefix. The details related to the protocol stack and the message flows required to negotiate and configure IPv4 address and IPv6 prefix(es) will be described in the next sections.
From an ISPs perspective I can see why they would only want to offer a single connection on a Radius server for accounting etc. It so happens that on one of my sites their DSLAM is incorrectly configured to allow multiple sessions hence the Netgear kit works in that site only.
Netgear have advised me that they WILL NOT change this behaviour and I note they do not appear to be a member of the broadband forum. So I would strongly advise people to check their ISP's IPv6 implementation before purchasing their kit.
Mark
- DaneANETGEAR Employee Retired
Hi MCFH1,
Welcome to the community! :)
I appreciate that you shared this information here in the community as this would help community members be aware of.
DaneA
NETGEAR Community Team
Since you were able to get in touch with NETGEAR Support, I believe your concern has been raised to the engineering team. However, you may want to post your concern as a request in the Idea Exchange for Business here so that the development team can see what should be changed or be implemented on the FVS336Gv3. Be reminded that the more kudos given by community members to your request will help as the development team will be reviewing the post that has the most kudos and might be considered.
DaneA
- diepesAspirant
Does this mean there is no Netgear support for IPv6 ISP's ?
My isp: BigPipe@New Zealand.
Are there any links on how to troubleshoot Netgear IPv6 issues ?
- MCFH1TutorAnything you can do to convince Netgear to change this approach as the router should not be sold as IPv6 compatible would be appreciated
