Herbie555
Mar 25, 2016Tutor
FVS316G Frequent Rebooting
Greetings, After close to three years of mostly trouble-free use, our FVS318G has started rebooting several times a day, obviously causing frequent network drop-outs. Once this started happenin...
- Mar 25, 2016
Hi Herbie555,
So, this could be a hardware issue, I don't see anything in the logs that would tell me this but the log data could be filling the memory causing the reboot. I would look to factory default the router and reconfigure manually. If the reboot still happens reflash the firmware again and see if the rebooting stops. Also, disable any logging period until you have completed the reset and firmware flash.
If you have already done all of this you will need to contact support and seek in-warranty hardware check.
Alex
AlexPe
Mar 25, 2016NETGEAR Expert
Hi Herbie555,
Alex
- Herbie555Mar 28, 2016Tutor
AlexPe, thanks for following up with me. I wanted to give everything you've suggested a good long try.
Resetting to defaults alone did not solve the issue. Have now reflashed firmware and reset defaults again. Will let this shake out for a few hours.
I'm disappointed with the idea that I might have a hardware problem after only 3 years on a device with no moving parts, but I'll stick with it to see what happens.
Thanks again.
- AlexPeMar 29, 2016NETGEAR Expert
Hi Herbie,
I can understand your frustration with the issue if it does become a hardware issue. More often than not with the Prosafe line of products a configuration entry or two gets corrupted or the device just begins to encounter issues after being in service for a long time. That is why we recommend the factory reset and reconfigure. I remember working on the FVS338 and that being the number 1 resolution for those machines. If that didn't fix it going forward it was definitely a hardware related issue in terms of dropping packets and/or random reboots.
Thanks for giving a try and being patient with this machine.
I hope it continues working in good operationg going forward.
AlexPe
- Herbie555Apr 02, 2016Tutor
So it looks like a full-reflash and reset to factory defaults did the trick. I'm now looking at Up-time of 4 days, 12-hours, whereas I was rebooting every couple of hours previously.
Thanks much.
- DaneAApr 03, 2016NETGEAR Employee Retired
Hi Herbie555,
On behalf of AlexPe, you're welcome. :) I'm glad that it is working now.
I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Cheers,DaneANETGEAR Community Team - Herbie555Apr 09, 2016Tutor
Looks like I spoke too soon. After almost a week of regular operation, I'm back to reboots every couple of hours.
Presuming hardware failure. Unit originally installed on 03-June-2013, so I got less than 3 years of operation in a climate controlled home under moderate usage.
Have replaced with a competitor's router.
- DaneAApr 11, 2016NETGEAR Employee Retired
Hi Herbie555,
Since the same problem has recur, I encourage you to open an online case with NETGEAR Support. Kindly state the troubleshooting steps you did to isolate the problem. If ever the device hardware is found faulty, please be ready to submit a soft copy of the Proof of Purchase or Sales Invoice of the FVS318G for warranty verification via the online case. If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
