Margian
Jan 08, 2017Aspirant
Frequently need to reboot the switch to re-estblish connection to the router
Netgear ProSafe (GS116NA) v2 16-Port Gigabit Ethernet Switch.
I have had the switch installed for some time and I have a small home network with 5 remote ethernet ports in various rooms. However, I have found on quite a few occasions that I lose connection to the router (and therefore the internet) from my Mac and / or from a Wireless Access Point in another room. As soon as I power off / power on the Netgear switch, normal service is resumed. What's the issue and how can I fix it? Can I schedule an overnight reboot? All ideas welcome - thanks!
Hi Margian,
It indeed appears that the switch causes the intermittent connectivity. Yes, you'll need to contact support for the replacement of the unit. You can refer to this link so that they won't be asking you the same questions again.
Thanks,
- JohnRoNETGEAR Employee Retired
Hello Margian,
Welcome to the community!
The GS116v2 is only a plug-and-play switch, it does not have a management UI or configuration page. There is no option to set a reboot schedule. Imagine this switch as just a few extra ports of your router. Try and isolate the issue by doing a ping test from the devices connected to the switch, check the LEDs when you lose the connection. Try and connect the power supply into a different plug. If all else fail, I suggest contacting our Support Team for replacement.
Thanks,
- MargianAspirant
Thanks JohnRo
Since writing I have managed to gather further evidence as follows:
Despite moving my WAP to another Cat 5 socket, I had the same issue as before (but still based on the same port from the switch)
Tonight I had a failure of internet to both the WAP and my hard-wired Apple TV box. Both came up immediatelky when I unplugged and re-plugged the switch
I have now moved the cable connecting the router to the switch from port 1 to port 3 on the router and from port 8 to port 6 on the switch just in case one of the ports was freezing - but I'm beginning to think the switch itself is faulty as I can't imagine how I'd get an intermittent fault on a cable!
Assuming the switch is indeed faulty, do I need to contact support as poer your link below and, if so, what shoudl I tell them (or do they have access to this blog?)
Thanks again!
