Herbie555
Mar 25, 2016Tutor
FVS316G Frequent Rebooting
Greetings, After close to three years of mostly trouble-free use, our FVS318G has started rebooting several times a day, obviously causing frequent network drop-outs. Once this started happenin...
- Mar 25, 2016
Hi Herbie555,
So, this could be a hardware issue, I don't see anything in the logs that would tell me this but the log data could be filling the memory causing the reboot. I would look to factory default the router and reconfigure manually. If the reboot still happens reflash the firmware again and see if the rebooting stops. Also, disable any logging period until you have completed the reset and firmware flash.
If you have already done all of this you will need to contact support and seek in-warranty hardware check.
Alex
Herbie555
Apr 02, 2016Tutor
So it looks like a full-reflash and reset to factory defaults did the trick. I'm now looking at Up-time of 4 days, 12-hours, whereas I was rebooting every couple of hours previously.
Thanks much.
DaneA
Apr 03, 2016NETGEAR Employee Retired
Hi Herbie555,
On behalf of AlexPe, you're welcome. :) I'm glad that it is working now.
I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
