MasterBrian
Jul 29, 2016Aspirant
FVS318G - All lights just flash and no connectivity
As the title says all the lights flash and it doesn't seem to connect to any computers. We've replaced the modem that was hooked to router, but still no internet and I can't even access the browser to check settings. Any idea?
I'm thinking factory reset, firmware upgrade and load backuped settings.
Thanks for anything.....
Hello MasterBrian,
You are welcome! Please give us an update once you get the replacement unit. Otherwise you can mark this thread as "Accept as Solution".
Thanks,
- JohnRoNETGEAR Employee Retired
Hello MasterBrian,
Since you have a backup config, I believe that resetting it to factory default should do the trick.
Thanks,
- MasterBrianAspirantWell I've tried to reset it and nothing. I've tried while on, I've tried while off, I've tried holding reset while off and turning in. No matter what I do the lights just flash...
- DaneANETGEAR Employee Retired
Hi MasterBrian,
It seems that your FVS318G is faulty since the lights are still flashing no matter what you do. I advise you to open an online case with NETGEAR Support at anytime. Let them know what is the status of your FVS318G. Attach a pdf copy of the Proof of Purchase or Sales Invoice of your FVS318G for hardware warranty verification. If the hardware warranty is still valid, then an online replacement will follow.
DaneANETGEAR Community Team
I called and they are doing an RMA, thanks for the help!
