Win7_Was_My_Ide
Jan 24, 2013Aspirant
FVS318G - port forwarding not working
I have a FVS318G router with firmware 3.0.7-34. A VPN is running between two sites, each have an identical FVS318G router, both using DDNS. The VPN didn't take long to set up, even though I had no...
Daedalus01
Not sure if you have the little tick box as I do not have that particular router, but there should a box that says "translate to port". Click that (looks like 8079 internally) and enter that port number. Thats how I've been doing it on my FVS336Gv2 for quite a while.
