Win7_Was_My_Ide
Jan 24, 2013Aspirant
FVS318G - port forwarding not working
I have a FVS318G router with firmware 3.0.7-34. A VPN is running between two sites, each have an identical FVS318G router, both using DDNS. The VPN didn't take long to set up, even though I had no...
jmizoguchi
Jan 24, 2013Virtuoso
But I can't seem to open the port ON THE ROUTER. The Shields Up! website always shows my port 8079 is in STEALTH.
because stealth mode is enabled at default
http://interface.netgear-forum.com/FVS336G/attack_checks.htm
You should fine same with FVS318G.. I believe
