Win7_Was_My_Ide
Jan 24, 2013Aspirant
FVS318G - port forwarding not working
I have a FVS318G router with firmware 3.0.7-34. A VPN is running between two sites, each have an identical FVS318G router, both using DDNS. The VPN didn't take long to set up, even though I had no...
Win7_Was_My_Ide
Disabling stealth mode makes no difference. Shields Up! simply says the port is "Closed" instead of in "Stealth". The problem is I cannot OPEN a port for port forwarding. The only port I can open and close is the one for remote admin (Administration -> Remote Management).
