Win7_Was_My_Ide
Jan 24, 2013Aspirant
FVS318G - port forwarding not working
I have a FVS318G router with firmware 3.0.7-34. A VPN is running between two sites, each have an identical FVS318G router, both using DDNS. The VPN didn't take long to set up, even though I had no...
Win7_Was_My_Ide
adit wrote: The port say it is closed because the server isn't responding to 8079, probably just port 80/443.
Like Daedalus said, you need to translate 8079 to 80.
As I mentioned in my original post, the web server listens to port 8079, not 80. It does respond to 8079, since I can access the web server locally with http://192.168.2.12:8079
