ChunLee's avatar
ChunLee
FVS318G Port Forward Fail
Hi All,
I cannot forward port 5901-5903, those port use for remote the client PC with UltraVNC.
- Set the 3 ports on different service name.
- Set signle inbound rule for each port.
Can anyone tell me with I am missing?
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello ChunLee,
    Welcome to the community!
    I have some questions for us to isolate your issue properly. I have listed them below:
    1.Are you getting any error messages upon opening the ports?
    2. What is the firmware version you are currently using?
    I also would like to request for sreenshots (firewall rules) to be sent to me through PM.
    I'll look forward to your response.
    Thanks,
    • ChunLee's avatar
      ChunLee
      Dear JohnRo
      No error to opening the port, the firmware version is 4.3.3-3.
      • JohnRo's avatar
        JohnRo
        Hi ChunLee,
        The settings looks good, try changing the WAN users to "ANY" and see if it will make any ddiference. What modem are you using?
        Thanks,
ProSupport for Business
