verax99's avatar
verax99
Follower
Feb 07, 2016
fvs318g stops passing traffic
Hi
I just installed a fvs318gv2 at a clients office
really simple setup, but for some reason it works for a while (15-20min) and then stops passing traffic
i upgraded the firmware to the lastest
after restart it works for awhile and then stops again
any ideas anybody
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi verax99,
    Welcome to the community! :)
    Kindly answer the questions below:
    a.  How is everything connected?  Kindly post an image or screenshot of your detailed network setup.
    b.  Did you perform a factory reset the FVS318Gv2 after successfully upgraded the firmware?  If not yet, it is recommended to perform a factory reset to the FVS318Gv2 after doing a firmware upgrade then reconfigure it from scratch.
    c. Do you have a DSL or cable internet connection?
    I look forward to your response.
    DaneA
    NETGEAR Community Team
    • Tintifax78's avatar
      Tintifax78
      Hi!
      I Have the same Problem with my FVS 318G.
      After 2- 3 hours the Router stops Traffic to the Internet. The Local Network is still working.
      The Routers Wan Port is replying to Ping´s from the Internet.
      After restarting the connected Cable modem (router is still powerd on) everthing is fine for the next 2-3 hours...
      i`ve done Firmware Update and Factory Reset already.
      The FVS 318 is about a Month routing my Network. ´till now everything was fine...
      • DaneA's avatar
        DaneA
        Hi Tintifax78,
        a. Have you tried to connect a PC directly to your cable modem and check if the internet connection is fine?
        b. Since you mentioned that everything was fine before, are there any changes made on your existing network such as have you upgraded your internet subscription with your Internet Service Provider?
        c. What is the behavior of the WAn port LED light of the FVS318G?
        DaneA
ProSupport for Business
