Muessigb
Jun 21, 2016Tutor
FVS318G Telnet LAN<>WAN firewall settings not working
Hello, when logging into the router via telnet and accessing the fw / lan-wan settings, I cannot use the show function nor can I disable or enable any rules. I need this to work for an automated ...
Danthem
Jun 30, 2016NETGEAR Employee Retired
Personally I'm a big fan of he FVS336gv3.. It's around 200 I'd guess, especially if you can find some discount. I can see Amazon reviews are not too amazing but they are very few and as someone who deals with a whole bunch of them I think they're great.
Banana-pi is definitely an interesting piece, I've been eyeing one for myself at home but I would probably not implement a b-pi based solution in a business Network.. It all comes down to what the requirements are though, in some scenarios it would be fine I guess :)
- MuessigbJul 02, 2016Tutor
Thank you for your suggestion.
So finally I decided in favor of the PC-Engines APU.1D4 router which can route 400-500 Mbit/s, has 4 GB DDR3 RAM, a dual core AMD processor at 1 GHz and a 16 GB server-grade SSD. It also has 3 gigabit Ethernet interfaces that are connected through PCI-Express.
It will be running pfSense.
