lpasekof
Jul 22, 2016Aspirant
FVS318G won't reconnect to router without reboot
I have a FVS318G firewall connecting to an Adtran Netvanta 3430 router. Periodically (frequently) performance over either the network or the T1 degrades to where I need to reboot. Not sure if this ...
JohnRo
Jul 22, 2016NETGEAR Employee Retired
Hello lpasekof,
Welcome to the community!
Are you using the FVS318G as a firewall or as a switch? If you have two routers connected to each other you will experience double NAT. Try isolating the issue by using the different scenarios below:
- Remove the FVS318G from the network, or connect a PC directly to the Adtran router. See if you will experience the same performance issue.
- Use the FVS318G as your main router, removing the Adtran router. See if this will fix the issue.
If one or both of the scenarios work, then it only means that there is something going on with the two routers.
- lpasekofJul 22, 2016Aspirant
I'm using the FSG more as a switch. Not sure I can remove the Adtran (carrier provided), though I can try. It's what provides the interface to the T1. I have connected directly to the Adtran with a PC. Never had any issues with that. The carrier provides only 5 IP addresses through the router. I think I'm doing all the NATing through the FSB - but I could be wrong.
I tend to agree the two devices are now working and playing well together. I'm just not sure how to fix.
Typo - NOT working and playing well together.
- JohnRoJul 22, 2016NETGEAR Employee Retired
Hi lpasekof,
I see, can you PM me a screenshot of the FVS' Router status? Go to the FVS' user interface and got to Monitoring>Router staus. I'll check if it's passing the correct IP.
Thanks,
