lpasekof
Jul 22, 2016Aspirant
FVS318G won't reconnect to router without reboot
I have a FVS318G firewall connecting to an Adtran Netvanta 3430 router. Periodically (frequently) performance over either the network or the T1 degrades to where I need to reboot. Not sure if this ...
lpasekof
I'm using the FSG more as a switch. Not sure I can remove the Adtran (carrier provided), though I can try. It's what provides the interface to the T1. I have connected directly to the Adtran with a PC. Never had any issues with that. The carrier provides only 5 IP addresses through the router. I think I'm doing all the NATing through the FSB - but I could be wrong.
I tend to agree the two devices are now working and playing well together. I'm just not sure how to fix.
lpasekof
Typo - NOT working and playing well together.
- JohnRoJul 22, 2016NETGEAR Employee Retired
Hi lpasekof,
I see, can you PM me a screenshot of the FVS' Router status? Go to the FVS' user interface and got to Monitoring>Router staus. I'll check if it's passing the correct IP.
Thanks,
- lpasekofJul 22, 2016Aspirant
PM? OK, now I'm going to show my ignorance. :manfrustrated: I can't paste into this window, nor does it appear I can add attachments. How do I PM?
