Nolantech
Apr 18, 2016Aspirant
fvs318gv2 loosing intenet, HTB: quantum of class 10001 is big consider r2q change
I have several VPN firewalls that loose internet connection intermittenly. The log shows this, HTB: quantum of class 10001 is big consider r2q change. Also could show 11024 instead of 10001 or both. ...
- Jan 06, 2017
Thanks for posting the info about the MTU change. We've been having a similar issue for weeks, I adjusted the MTU size from default (1500) to 1492 a couple of days ago after seeing this and I haven't had an outage since. I am seeing some new messages in the logfile though, about every two hours I get something like:
Fri Jan 6 15:40:06 2017((GMT-0600)) [FVS336GV3][Kernel][KERNEL] Port 0 receive error code 4, packet dropped
Fri Jan 6 15:40:06 2017((GMT-0600)) [FVS336GV3][Kernel][KERNEL] Port 0 receive error code 4, packet droppedDoes anyone know what "error code 4" means and whether it's anything to be concerned about?
okadis
May 09, 2016Guide
Dear community,
I think I can add something to this thread. We are facing the same problems with a FVS336v3 (bigger brother) and same firmware version (4.3.3-6).
We have 2 different WANs connected to the device. When the quantum-messages appear the device is restarting the IPv4-Stack only for WAN2, which is currently a backup for WAN1. But despite WAN1 being responsible for the normal internet traffic, any internet connection is broken for about 2 minutes.
To answer the other questions (maybe we are facing totally different problems with same outcome):
- What is the firmware version currently installed on the FVS318Gv2?
- 4.3.3-6
- Do you have QoS configured on the FVS318Gv2?
- No.
- What changes have you made before you experienced the issue?
- None for about 5 months.
- Do you lose the internet connection only when VPN is connected?
- As there are coworkers connected vie IPSec almost all the time during working hours and we only notice these problems when internet is down I cannot tell wether it only happens when VPN is established.
- Do you have firewalls rules setup?
- Yes. Mainly outbound rules to seperate the traffic for the 2 WANs.
Best regards
Michael Biber
idiez
Nov 18, 2016Aspirant
Dear Community
I also have exactly the same problem, same router FVS336v3, same firmware 4.3.3-6, same issue with 2 WANs
Many thanks
Best regards
- fwblackDec 22, 2016Aspirant
Getting same problem with FVS318Gv2, firmware: 4.3.4-2
QOS, no
Have to restart it a lot because it will just stop communicating with the cable modem.
several instances of "HTB: quantum of class 11024 is big. Consider r2q change." in log prior to crash.
I should have added that the fvs318gv2 is only a few weeks old and did not do this until 2 days ago... have had to restart it 3 times already today, considering sending it back for a refund and getting another brand. The lack of support after reading through these forums is concerning.
- fwblackDec 23, 2016Aspirant
OK, I take back what I said about lack of support. Since my firewall was new, I was able to open a support ticket received some help that appears to have solved the issue. I was advised to change the MTU size from 1500 to 1492. You change it under WAN settings: Network Configuration -> Broadband -> Advanced, so far, after doing this, I've not had to restart the firewall.
