Nolantech
Apr 18, 2016Aspirant
fvs318gv2 loosing intenet, HTB: quantum of class 10001 is big consider r2q change
I have several VPN firewalls that loose internet connection intermittenly. The log shows this, HTB: quantum of class 10001 is big consider r2q change. Also could show 11024 instead of 10001 or both. ...
- Jan 06, 2017
Thanks for posting the info about the MTU change. We've been having a similar issue for weeks, I adjusted the MTU size from default (1500) to 1492 a couple of days ago after seeing this and I haven't had an outage since. I am seeing some new messages in the logfile though, about every two hours I get something like:
Fri Jan 6 15:40:06 2017((GMT-0600)) [FVS336GV3][Kernel][KERNEL] Port 0 receive error code 4, packet dropped
Fri Jan 6 15:40:06 2017((GMT-0600)) [FVS336GV3][Kernel][KERNEL] Port 0 receive error code 4, packet droppedDoes anyone know what "error code 4" means and whether it's anything to be concerned about?
fwblack
Dec 23, 2016Aspirant
OK, I take back what I said about lack of support. Since my firewall was new, I was able to open a support ticket received some help that appears to have solved the issue. I was advised to change the MTU size from 1500 to 1492. You change it under WAN settings: Network Configuration -> Broadband -> Advanced, so far, after doing this, I've not had to restart the firewall.
GopherGuy
Jan 06, 2017Tutor
