k1llercop
May 05, 2016Aspirant
FVS318N Setup help
Hello, I'm currently trying to setup a FVS318N in our office. I am rather confused though. Basically we have an ADSL router in the room and what I would like to do is connect that to the FVS318N an...
DaneA
May 05, 2016NETGEAR Employee Retired
Hi k1llercop,
Welcome to the community! :)
I found out online that the Sagemcomm 2704N is a combination of ADSL modem and wireless router. For you to maximize the functionality of the FVS318N as a VPN firewall, I suggest you to configure the Sagemcomm 2704N as a modem-only device. Then, connect the Sagemcomm 2704N to the WAN port of the FVS318N. Thus, making the FVS318N as the main router since the WAN IP Address will be registered to it. Then, configure the FVS318N and finally you may connect your NAS to one of the LAN ports of the FVS318N.
DaneA
NETGEAR Community Team
