k1llercop
May 05, 2016Aspirant
FVS318N Setup help
Hello, I'm currently trying to setup a FVS318N in our office. I am rather confused though. Basically we have an ADSL router in the room and what I would like to do is connect that to the FVS318N an...
DaneA
May 08, 2016NETGEAR Employee Retired
@killercop,
Were you able to try to set the Sagemcomm 2704N as a modem-only device set to full-bridge mode? Then, making the FVS318N set as the main router?
DaneA
NETGEAR Community Team
k1llercop
May 11, 2016Aspirant
Hello DaneA thanks for the response. Unfortunately there are no options on the Sagemcomm to put it into modem only mode. Do you hava any other suggestions ?
- DaneAMay 11, 2016NETGEAR Employee Retired
Hi k1llercop,
Do you have an old DSL modem that you can try to use? Or, if ever the Sagemcom 2704N was provided by your ISP to you, you might want to exchange it to a device that is a combination of ADSL modem and router wherein its possible to configure it as a modem-only device set to full-bridge mode.
DaneA
- DaneAMay 15, 2016NETGEAR Employee Retired
Hi k1llercop,
Just want to follow-up on this.
DaneA
- JohnRoMay 18, 2016NETGEAR Employee Retired
Hello k1llercop,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
