k1llercop
May 05, 2016Aspirant
FVS318N Setup help
Hello, I'm currently trying to setup a FVS318N in our office. I am rather confused though. Basically we have an ADSL router in the room and what I would like to do is connect that to the FVS318N an...
k1llercop
May 11, 2016Aspirant
Hello DaneA thanks for the response. Unfortunately there are no options on the Sagemcomm to put it into modem only mode. Do you hava any other suggestions ?
DaneA
May 11, 2016NETGEAR Employee Retired
Hi k1llercop,
Do you have an old DSL modem that you can try to use? Or, if ever the Sagemcom 2704N was provided by your ISP to you, you might want to exchange it to a device that is a combination of ADSL modem and router wherein its possible to configure it as a modem-only device set to full-bridge mode.
DaneA
NETGEAR Community Team
