ChamberGeek
Oct 13, 2014Aspirant
FVS318N Wireless Intermittent Connection
We are using a FVS318N ProSafe Firewall/Router. Firmware 4.2.1-2 IPv4, Static IP, NAT routing. Wireless Security is WPA+WPA2, TKIP+CCMP, PSK. *Attached is screenshot of the radio settings. I purpos...
Nhellie
Dec 26, 2014Virtuoso
pplaut wrote: I have been having this problem since I purchased the FVS318N a couple of years ago and still have not figured out what the problem is. I am on the latest firmware Firmware Version 4.3.1-31 and did a complete factory reset with the new firmware. It seems to work better if I do not create additional wireless profiles, which of course, is one of the reasons I purchased the router to begin with.
The wireless works for a few days and then just disappears from the broadcast list requiring a reboot.
It is just the wireless you are having issues with? Do you still have access to the UI when the SSIDs disappear?
