ChamberGeek
Oct 13, 2014Aspirant
FVS318N Wireless Intermittent Connection
We are using a FVS318N ProSafe Firewall/Router. Firmware 4.2.1-2 IPv4, Static IP, NAT routing. Wireless Security is WPA+WPA2, TKIP+CCMP, PSK. *Attached is screenshot of the radio settings. I purpos...
Nhellie
Jan 09, 2015Virtuoso
pplaut,
How often does the wireless disconnect? Are you still able to access the router when this happens(on a wired connection of course)?
Have you considered calling support? It might have something to do with the hardware.
