ChamberGeek
Oct 13, 2014Aspirant
FVS318N Wireless Intermittent Connection
We are using a FVS318N ProSafe Firewall/Router. Firmware 4.2.1-2 IPv4, Static IP, NAT routing. Wireless Security is WPA+WPA2, TKIP+CCMP, PSK. *Attached is screenshot of the radio settings. I purpos...
SamirD
Jan 09, 2015Prodigy
If you don't need any features in the most current firmware, try rolling back to the one I'm using. The wifi issues are a bit different and don't seem to be nearly as bad as what you're experiencing.
pplaut wrote: Disregard the date time question, I got that figured out...
But it still loses WiFi connections during the day..
P.
