greenhood
Feb 14, 2013Aspirant
FVS336G v1 Random Reboots
I really need some help and / or insight into this issue.. otherwise I feel like I might need to RMA the device.. My router has randomly rebooted 2x in last 36 hours.. I am running firmware ve...
greenhood
Mar 22, 2013Aspirant
NetGear was very helpfully and RMA'd the unit! They ending up sending me the V2 version and it has been working great.. previously the unit was rebooting every 48-72 hours and logging into the unit and clicking between a few tabs would make the unit reboot.. it was solid for a long time, but just eventually bit the dust..
I am likely to believe the power supply or something related to hardware was failing.. wiping the unit out, re-installing a new firmware and rebuilding the profiles from scratch had no impact..
The new unit did the trick...
WAY TO GO NETGEAR!
-R
WAY TO GO NETGEAR!
-R
