m1k3y02
Aug 31, 2023Follower
FVS336g V3 wrong firmware
Hi, I upgraded firmware of my FVS336G V3 with the latest version for V1. I can't connect. DHCP doesn't assign IP, manual configuration does help so the factory reset. Is there any hope for ...
slowpoke338
Dec 06, 2023Aspirant
Have you tried going back to the firmware that worked?
- ErikODec 12, 2023NETGEAR Moderator
Hello,
I would be very surprised if there is any way to recover the situation. The equipment would typically not even let you try an upgrade with an incorrect version, so if the FW upgrade went through it is probably a lost cause.
