DaytonRobinson
Nov 30, 2015Follower
FVS336G VPN set up behind a nat router with a DHCP WAN
Hello all,
I have a FVS336G sitting behind a router that pulls its WAN address via DHCP. I had considered bridging through to the router but since it is DHCP I am thinking there is a better way of doig this. I manage both routers but the reason behind the first router is it is a 4G verizon Cradlepoint so I have to keep it as my bDemarc. I have looked into dynamic DNS as a possible solution but can not get a clear handle if it will do what i need or more importantly how to set it up. Any shared ideas or solutions would be great!
-Dayton
1 Reply
- JohnRoNETGEAR Employee Retired
Hello DaytonRobinson,
What type of setup do you want to achieve? Do you want to run VPN and/or let the FVS336G manage your inbound and outbound connection? Dynamic DNS is a good solution if you want to have remote access on devices behind the FVS336G and it can do a lot more. You can also use DMZ but we need to know what you want to accomplish.
Looking forward to your response.
Thanks,
- Sep 04, 2015Retired_Member
