vpnman's avatar
vpnman
Guide
Aug 21, 2016
FVS336Gv3 - Help in configuring router
We have a Netgear FVS336Gv3 running latest firmware (V4.3.4-1).   The FVS336Gv3 has a single LAN network with 4 devices and each have the following IP address:  IP_A, IP_B, IP_C, IP_D.   It also has a single WAN network.
What we'd like to do is to configure the FVS336Gv3 to only allow the IP_A device to communicate with IP_D device but everybody else (IP_B and IP_C) are disallowed to communicate with IP_D device.   Note that IP_A, IP_B, and IP_C are allowed to communicate with each other.
Would appreciate it if someone can provide directions in configuring the FVS336Gv3 to accomplish the above.
Al
  • Hi vpnman,
    Just want to follow-up.  Any updates?
    DaneA
    NETGEAR Community Team
    • vpnman's avatar
      vpnman
      Guide
      Hi DaneA,
      Thanks for your response.   Will a Netgear ProSAFE M4100 unit be able to accomplish this and support the additional requirements below?
      • In addition to IP_A device, to only allow a particular VPN client (coming from WAN side) with VPN_IP_Z address to access IP_D device and all other VPN clients are denied access to IP_D device?
      • Can a set of LAN IP address (ex: coming from a port connected to a WIFI access point) be put in a group and manage this group in a ACL rule (ex: deny this group access to IP_D)?
      vpnman
      • DaneA's avatar
        DaneA
        NETGEAR Employee Retired
        Hi vpnman,
        About the 1st additional requirement, I believe it can be configured on the VPN policies of the FVS336Gv3.  While the 2nd additional requirement, can be configured on the M4100 switch as an ACL rule.
        DaneA
ProSupport for Business
