Tako30
Jul 25, 2017Aspirant
fvs336gv3 VPN Client Not Working
Good Day People,
I am having trouble establishing conection to my office location using the NetGear VPn client software and following the step by step instruction in configuring both the server side and client side of the VPN.
Upon finalizing both configurations I open the client on my laptop and attempt to open the tunnel.
The tunnel opens succesfully both once I try to acces my office network resources none of them are available. I tried pinging afew other components within that network and none of the attempts are succesful.
If anyone has expereince any ssimilar issues please help me. I have contacted support about this with out any succes on troubleshooting.
- JohnC_VNETGEAR Employee Retired
Hi Tako30,
Welcome to the community!
It seems that you were able to connect thru VPN but you cannot ping the resources on the other end. In order for you to ping windows pc, you need to disable the windows firewall and the anti-virus on the computer that you wanted to ping. The LAN IP Address of your remote location should be different from your local network. It shouldn't be the same as it may cause a conflict. You may try to ping printers or scanners as this devices doesn't have any firewall.
- Tako30Aspirant
I have tried that with a few computers but the results are the same. Also not all the devices that I'm trying to ping are Windows based, there is a NAS drive, amongst other equipment... not able to ping any of it.
On Thursday July 27th, 2017 another NetGear technical support associate tried to help me fix this issue without any solutions. He recommended I update my Firmware to the latest version, which didn't change anything.
If anyone else out there has any other solutinos please let me know.
Thank you!
As I checked the case that you have that you are only using a free trial version of the VPN client. Usually our firewalls have a free VPN license key included in the package. You were also stuck in phase 2, it means that you were able to communicate with the firewall already and you just need to double check the settings that you have. May you be able to check if there is ANY service created under inbound rules on your firewall? Please disable it and indicate an IP on "VPN client address".
Please refer to this manual.
I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
