UlfLaursen
Dec 06, 2011Aspirant
FVS338 and iPhone VPN
Hallo I have tried to find a description on how to configure my FVS338 have an iPhone connect to it via VPN, but have had no luck yet. I have the latest firmware on my FVS338, which should suppo...
jmizoguchi
Feb 05, 2012Virtuoso
Common issues are data package which are not enterprise data can cause issues
Also ip pool can not be same as your LAN subnet
You can test with wireless router hooked up on WAN side you can see it does work
