UlfLaursen
Dec 06, 2011Aspirant
FVS338 and iPhone VPN
Hallo I have tried to find a description on how to configure my FVS338 have an iPhone connect to it via VPN, but have had no luck yet. I have the latest firmware on my FVS338, which should suppo...
xeo2002
Apr 14, 2012Novice
I am connecting to VPN but still can not see my network all LAN devices not responding on ping , I have checked all you told me , IP pool adresses are the same like my LAN , nothing , I can see VPN icon on my iphone and then see status of the connection on the Iphone all looks ok adress of the remote (iphone device is assigned properlly from the ip pool confiugred in router , all logs in router also look ok but , where is my LAN , this vpn is useless , when Netgear will start doing something to solve it?
