Tridac
Feb 13, 2019Aspirant
FVS338 Not Forwarding Packets
FVS338 Port Forwarding Failure
Hi,
Posted this query on another forum, but it's been suggested that I post it here. A port forwarding problem, started with an FVS318, now an FVS338, neither of which foreward traffic from wan to lan host.
Using an FVS338, older model, but latest firmware from 2013 and reset defaults to start.
Setup is as follows:
Mode: Nat, not router
DHCP: Disabled
Routing: No entries
External Wan ip: 192.9.200.252
Gw: 192.9.200.254
Mask: 255.255.255.0
Dns: 208.67.220.220, 208.67.222.222
Internal Lan Ip: 10.10.10.250
Telnet host is at: 10.10.10.150
Telnet client is at: 192.9.200.214
Start by trying something simple, telnet from wan to a lan host, so set up a rule
as follows:
Default Outbound Policy: Allow Always
No added rules
Inbound Services
Service Name Filter LAN Server IP Address LAN Users WAN Users Destination Bandwidth Profile Log
TELNET Allow Always 10.10.10.150 ANY WAN1 NONE Always
Result log is:
[kernel] LOG_PACKET[DROP] IN=WAN OUT=LAN src=192.9.200.214 DST=10.10.10.150 PROTO=TCP SPT=36372 DPT=23
Outgoing pings from lan to wan host and ntp time update works fine, so the
network is ok.
I'm just trying to link 2 subnets for added security, no need for speed, so this unit should be fine as proof of concept. Just followed the instructions in the manual but doesn't work and the log files don't say much as to the cause. Did try pointing zenmap at the wan port, which says telnet, 23 is open, but the box is dropping the packets, not forwarding them to the lan side client. I know this is an older unit, but it should still work as per the manual...
Have setup and using pfsense, opnsense and other open source firewalls for years now and do embedded development for work, so this should be a 1/2 hour setup, right ?. Have used Netgear routers for years without a problem, as a simple outgoing nat router, but did port forwarding ever work on Netgear kit, or is there someting obvious i'm missing ?...
Chris
- DaneANETGEAR Employee Retired
Hi Tridac,
The latest firmware for the FVS338 is v3.1.1-08 which was posted last 2016. I suggest you to upgrade the firmware of your FVS338 to v3.1.1-08 then check if the same problem will occur. You can also perform a factory reset after upgrading the firmware to the latest version then reconfigure the setting from scratch in order to start clean using the latest firmware version. You can download firmware v3.1.1-08 here.
Just sharing the link below as reference about Forwarding Ports in the FVS338:
https://portforward.com/netgear/fvs338/
DaneA
NETGEAR Community Team
- TridacAspirant
Hi,
Thanks for the reply.I do have the latest firmware installed and did a factory settings reset after doing that and before reconfiguring the box. Just wondering what other dependencies there are in the setup that could be affecting things ?. Are there any undocumented diag commands to give more info on the log messages, internal routing and arp tables etc ?.
As i said, zenmap thinks telnet port 23 s open, but the box is dropping the packets, so sounds like an internal nat rule problem. Have no schedules defined either, that might be getting in the way...
Chris
Chris
- Nodism1125NETGEAR Expert
Is the FVS338 router is behind to another router link as modem/router combo? If yes, this might cause a Double NAT setup.
