HankLambert
Jul 22, 2015Aspirant
FVS338 VPN wont accept client VPN on WAN port, only LAN
I have an FVS338 with a single WAN connection. We have Bright House Business Internet, and their modem is in bridge mode passing our public address to the firewall. I have a Gateway to Gateway VPN es...
DaneA
Jul 23, 2015NETGEAR Employee Retired
Hi HankLambert,
Kindly access this link below about understanding VPN Logs on a Prosafe VPN Client software and this might help:
Understanding ProSafe VPN Client Logs
We will be looking forward to your response.
DaneA
Netgear Community Team
- HankLambertJul 24, 2015Aspirant
It's fixed. Unfortunately I made so many changes that I'm not sure which one fixed it. Thanks for the replies. I'm sorry about the delay, work has been overwhelming. I went through the VPN Client logs, I only got the following entries before the tunnel closed:
20150724 10:09:24:588 Default (SA Ikev 1Gateway-P1) SEND phase 1 Aggressive Mode [SA] [KEY_EXCH] [NONCE] [ID] [VID] [VID] [VID] [VID] [VID] [VID]
20150724 10:09:29:593 Default (SA Ikev 1Gateway-P1) SEND phase 1 Aggressive Mode [SA] [KEY_EXCH] [NONCE] [ID] [VID] [VID] [VID] [VID] [VID] [VID]
20150724 10:10:44:597 Default (SA Ikev 1Gateway-P1) SEND phase 1 Aggressive Mode [SA] [KEY_EXCH] [NONCE] [ID] [VID] [VID] [VID] [VID] [VID] [VID]
I made 1 change and got error messages about bad cookies. I'm not sure exactly what I did, but I finally got a tunnel. I then remoted into another laptop in a different city, copied the configuration, and acquired a tunnel.
Thanks for the replies and pointing me to the tutorial on the logs. Now I have something to fall back on if I run into another problem.
--Hank Lambert
- DaneAJul 26, 2015NETGEAR Employee Retired
