Paulk59
Feb 11, 2016Aspirant
FVS338 Wan state:Down
Problem - Cannot connect to internal CCTV and it cannot use SMTP to get out. Background - We have FTTC connected to BTOpenreach switch, from here we connect to Plusnet and then onto the FVS338. W...
JohnRo
Feb 11, 2016NETGEAR Employee Retired
Hello Paulk59,
Welcome to the community!
It appears that you are using a very old firmware, would you consider updating it first? How long have you been experiencing this issue? What changes have you made to your network before you experienced it?
Looking forward to your response.
Thanks,
- Paulk59Feb 19, 2016Aspirant
Hello John
Yes I would perform an upgrade if we knew where to get it from.
We are now able to send email out from 192.169.1.10 but the FVS338 itself still cannot send emails which is a little strange although we are sending the email to 192.168.1.254 which is the plusnet router, the same option is not (I believe) available within the Netgear device.
Thank you for your time and interest it's more than we get from Netgear support.
thanks
Paul
