Kobie
Jul 08, 2011Novice
FVX538 - Problems
Hello all: I am back, I have two FVX538 V2 units I have the following problems one of which has been ongoing for over a year. -======================= First Problem: I cannot get either of t...
adit
Jul 15, 2011Mentor
Hook up to the console port and read the boot script. Reply with how much Memory you have, as seen below.
Initiating BCM5380 ... ok
+starting api entry
Ethernet eth0: MAC address 00:0f:b5:8a:d9:99
IP: 192.168.16.244/255.255.255.0, Gateway: 0.0.0.0
Default server: 192.168.16.1, DNS server IP: 0.0.0.0
RedBoot(tm) bootstrap and debug environment [ROM]
Red Hat certified release, version 1.92p1 - built 19:39:46, Dec 11 2004
Platform: NetGear FVX538 (XScale)
Copyright (C) 2000, 2001, 2002, Red Hat, Inc.
RAM: 0x00000000-0x02000000, 0x0001e758-0x01fdd000 available
FLASH: 0x50000000 - 0x51000000, 128 blocks of 0x00020000 bytes each.
RedBoot> [COLOR=black]boot
[/COLOR]Partition Priority Firm/Cfg-Ver BuildTime FileName
appimg1(V) 8388745 3.0.4-19/2.1 Fri Aug 1 15:45:03 2008 fvx538_v3.0.4-19.i
mg
appimg2(V) 8388744 3.0.4-19/2.1 Fri Aug 1 15:45:03 2008 fvx538_v3.0.4-19.i
mg
Booting application image from partition appimg1 ...
Downloading Image to RAM location 0x1600000 ...
Transfering control to downloading Image at address 0x160024c ...
powering down the PHYs
Uncompressing Linux............................................. ................
.................................................. .. done, booting the kernel.
Linux version 2.6.10_mvl401 (build@TeamF1 Copyright (c) 2007, TeamF1, Inc.) (gcc
version 3.4.3 (MontaVista 3.4.3-25.0.30.0501131 2005-07-23)) #43 Fri Aug 1 15:4
4:54 IST 2008
CPU: XScale-IXP42x Family [690541c1] revision 1 (ARMv5TE)
CPU0: D VIVT undefined 5 cache
CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
Machine: Netgear FVX538
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists
Kernel command line: console=ttyS0,115200
PID hash table entries: 256 (order: 8, 4096 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 32MB = 32MB total
Memory: 28488KB available (1662K code, 456K data, 1764K init)
