wrf
Oct 05, 2011Tutor
FVX538 email settings lost on power cycle
I have two FVX538 routers running firmware 3.0.7-24 (the latest). They were both configured from a hard reset and have been running fine for months. They are configured to send log data daily via ema...
jmizoguchi
Oct 05, 2011Virtuoso
did you manually configure it? if you did restore the *.cfg file then had reset and manually configure is the first thing you want to do ..:)
