Hwayoung
Jul 04, 2018Initiate
How to open ports on SRX5308
Hi,
I was recently requested to open 3 ports for CCTVs. So I said YES with confidence as I expericed for a Synology NAS.
First, I created a serivce, and added it to inbound/outbound rules...
- Jul 05, 2018
Hi Hwayoung,
Welcome to the community! :)
Kindly answer the questions below:
a. Is the SRX5308 set as the main router wherein the Public WAN IP address is registered to it?
b. Do you have access to the settings CCTV cameras to double check if it is using the port numbers you have opened on the SRX5308?
c. How is everything connected? Are the CCTV cameras directly connected tot he SRX5308? It would be best if you post an image or screenshot of your detailed network setup.
Let me share the link below as reference guide:
DaneA
NETGEAR Community Team
DaneA
Jul 05, 2018NETGEAR Employee Retired
Hi Hwayoung,
DaneA
