jdrch
Jan 17, 2019Apprentice
How to use the BR500 as DHCP server with a Raspberry Pi (running Pi-hole) as a DNS server (no VLANs)
I'm considering replacing my TP-Link Archer C8 v1 with a BR500 so I can remotely access my LAN on the go via VPN. Currently I have the C8 set to use a Raspberry Pi running Pi-Hole (located on the sam...
- May 26, 2019
JohnC_VPer a chat with tech support earlier today, this isn't the case. The BR500's DCHP and DNS functionality are linked, so that disabling the former disables the latter also. While this runs counter to most consumer routers that allow users to separate the 2 functions such that the router handles one while the other is outsourced, it does make sense from a networking point of view as one of the roles of a DHCP server is to inform clients of the DNS server.
JohnC_V
Jan 18, 2019NETGEAR Employee Retired
Hi jdrch,
Welcome to our community! :)
As per checking, BR500 may work as your DHCP server even though your DNS server is the Raspberry Pi. Usually, other businesses uses remote DNS or local DNS in their network.
jdrch
May 26, 2019Apprentice
