BigMoneyTK
Mar 27, 2018Aspirant
HTB: quantum of class 11024 is big. Losing internet
I have several loose internet connection intermittenly. The log shows this, HTB: quantum of class 11024 is big consider r2q change. Also could show 11024 instead of 10001 or both. I'm looking for a s...
- May 03, 2018
Hi! Thank's for solution.
I'm doing a follow up to see any more error so far, still watching this log :
Tue Apr 17 11:29:31 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (209 bytes)
Tue Apr 17 11:25:06 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (209 bytes)
Tue Apr 17 08:34:25 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (552 bytes)
Mon Apr 16 18:24:19 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (324 bytes)As I have mentioned from my previous response, there might be possible that there is a DDOS attack. It is similar to the concern posted on the forum thread here. The logs states that the firewall received an improperly formatted TCP packet. It might be a hacker probing the firewall to see if it can breach the firewall's security. The firewall handles this correctly in which it discards the packet without any harm.
DaneA
NETGEAR Community Team
BigMoneyTK
Apr 05, 2018Aspirant
I'm sorry for the delay, follow the answers below :
a. Disconnect the FVS336Gv3 from the modem. Then, connect a PC directly to the modem and observe if the internet connection is stable. Is the internet connection fine when connected directly to the modem?
Positive, the internet connections keep stable. In both connections.
b. The modem where the FVS336Gv3 is connected to, is it a modem-only device or a combination of modem-router?
Modem-only
c. Are you using the DNS provided by your ISP? If yes, kindly try using Google DNS such as 8.8.8.8 or 8.8.4.4 then observe the internet connection as well as if the same logs will show up.
I put the google dns and it looked like it had normalized, but today it came back the problem
d. Since you mentioned, "When I connect two Wan connections, it drops," are you subscribed to 2 different ISPs?
Yes, i use load balance - weighted LB
e. Are there firewall rules configured on the FVS336Gv3? If yes, kindly try to disable (or delete) it then observe the internet connection through the FVS336Gv3 as well as if the same logs will appear.
ok, it was all right, but now you have these errors :
Thu Apr 5 11:19:40 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (209 bytes)
Thu Apr 5 11:09:40 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (209 bytes)
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change.
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] p->perfect 0000000000000000 p->h a800000004a02e00
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_dump(tp a8000000025f9780,fh 0x0,skb a800000005451380,t a800000003ac7010),p a800000006f74a00,r 0000000000000000,b a800000003ac7038
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_change(tp a8000000025f9780,handle 0x00000000,tca a800000007c05a80,arg a8000000028f3950),opt a800000005311a30,p a800000006f74a00,r 0000000000000000,*arg 0x0
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_get(tp a8000000025f9780,handle 0x00000000)
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_init(tp a8000000025f9780)
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_delete(tp a800000003a83f80,arg 0xa800000006f74a08),p a8000000025f9780,f 0000000000000000
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_walk(tp a800000003a83f80,walker a80000000251f900),p a8000000025f9780
Thu Apr 5 11:06:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_destroy(tp a800000003a83f80),p a8000000025f9780
Thu Apr 5 11:05:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change.
Thu Apr 5 11:05:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Thu Apr 5 11:05:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] p->perfect 0000000000000000 p->h a800000004e92800
Thu Apr 5 11:05:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_dump(tp a800000003a83f80,fh 0x0,skb a800000002ccb200,t a8000000037f9010),p a8000000025f9780,r 0000000000000000,b a8000000037f9038
Thu Apr 5 11:05:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_change(tp a800000003a83f80,handle 0x00000000,tca a800000007c05a80,arg a8000000038f7950),opt a800000004a02a30,p a8000000025f9780,r 0000000000000000,*arg 0x0
Thu Apr 5 11:05:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_get(tp a800000003a83f80,handle 0x00000000)
Thu Apr 5 11:05:55 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_init(tp a800000003a83f80)
Thu Apr 5 11:05:10 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device unregistering: ppp1
Thu Apr 5 11:05:10 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_delete(tp a800000006f70e00,arg 0xa800000006cfdd08),p a800000003826e80,f 0000000000000000
Thu Apr 5 11:05:10 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_walk(tp a800000006f70e00,walker a8000000028f3d00),p a800000003826e80
Thu Apr 5 11:05:10 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_destroy(tp a800000006f70e00),p a800000003826e80
Thu Apr 5 11:05:10 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device down: ppp1
Thu Apr 5 10:50:52 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change.
Thu Apr 5 10:50:52 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Thu Apr 5 10:50:52 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] p->perfect 0000000000000000 p->h a800000004a02600
Thu Apr 5 10:50:52 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_dump(tp a800000006f70e00,fh 0x0,skb a8000000062c2c80,t a8000000031fc010),p a800000003826e80,r 0000000000000000,b a8000000031fc038
Thu Apr 5 10:50:52 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_change(tp a800000006f70e00,handle 0x00000000,tca a800000007c05a80,arg a800000002d33950),opt a800000004e92630,p a800000003826e80,r 0000000000000000,*arg 0x0
Thu Apr 5 10:50:52 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_get(tp a800000006f70e00,handle 0x00000000)
Thu Apr 5 10:50:52 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_init(tp a800000006f70e00)
Thu Apr 5 10:48:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device unregistering: ppp1
Thu Apr 5 10:48:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_delete(tp a8000000027d7d00,arg 0xa800000003965708),p a800000006f08b00,f 0000000000000000
Thu Apr 5 10:48:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_walk(tp a8000000027d7d00,walker a800000002d33d00),p a800000006f08b00
Thu Apr 5 10:48:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_destroy(tp a8000000027d7d00),p a800000006f08b00
Thu Apr 5 10:48:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device down: ppp1
Thu Apr 5 09:41:32 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change.
Thu Apr 5 09:41:32 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Thu Apr 5 09:41:32 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] p->perfect 0000000000000000 p->h a800000004a02200
Thu Apr 5 09:41:32 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_dump(tp a8000000027d7d00,fh 0x0,skb a800000002845680,t a800000002e35010),p a800000006f08b00,r 0000000000000000,b a800000002e35038
Thu Apr 5 09:41:32 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_change(tp a8000000027d7d00,handle 0x00000000,tca a800000007c05a80,arg a800000002b07950),opt a800000004a02030,p a800000006f08b00,r 0000000000000000,*arg 0x0
Thu Apr 5 09:41:32 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_get(tp a8000000027d7d00,handle 0x00000000)
Thu Apr 5 09:41:32 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_init(tp a8000000027d7d00)
Thu Apr 5 09:39:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device unregistering: ppp1
Thu Apr 5 09:39:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_delete(tp a8000000027d7480,arg 0xa800000001756d88),p a800000006f08280,f 0000000000000000
Thu Apr 5 09:39:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_walk(tp a8000000027d7480,walker a8000000034cbd00),p a800000006f08280
Thu Apr 5 09:39:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_destroy(tp a8000000027d7480),p a800000006f08280
Thu Apr 5 09:39:27 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device down: ppp1
Thu Apr 5 08:16:57 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (68 bytes)
Thu Apr 5 03:40:42 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 11024 is big. Consider r2q change.
Thu Apr 5 03:40:42 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Thu Apr 5 03:40:42 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] p->perfect 0000000000000000 p->h a800000005311e00
Thu Apr 5 03:40:42 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_dump(tp a8000000027d7480,fh 0x0,skb a8000000062c4200,t a800000002628010),p a800000006f08280,r 0000000000000000,b a800000002628038
Thu Apr 5 03:40:42 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_change(tp a8000000027d7480,handle 0x00000000,tca a800000007c05a80,arg a800000002aab950),opt a800000004a02030,p a800000006f08280,r 0000000000000000,*arg 0x0
Thu Apr 5 03:40:42 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_get(tp a8000000027d7480,handle 0x00000000)
Thu Apr 5 03:40:42 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_init(tp a8000000027d7480)
Thu Apr 5 03:39:12 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device unregistering: ppp1
Thu Apr 5 03:39:12 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device down: ppp1
Thu Apr 5 02:40:47 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device unregistering: ppp1
Thu Apr 5 02:40:47 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_delete(tp a800000004f4e400,arg 0xa800000003edb288),p a8000000027d7180,f 0000000000000000
Thu Apr 5 02:40:47 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_walk(tp a800000004f4e400,walker a800000002413d00),p a8000000027d7180
Thu Apr 5 02:40:47 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] tcindex_destroy(tp a800000004f4e400),p a8000000027d7180
Thu Apr 5 02:40:42 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] IPsec: device down: ppp1
f. Are there requests from an unknown Public IP address? To check this, on the web-GUI of the FVS336Gv3, go to Monitoring > Firewall Logs & E-mail. Then, under the Accepted Packets section, check the boxes on both LAN-to-WAN and WAN-to-LAN.
I dit it now
DaneA
Apr 12, 2018NETGEAR Employee Retired
I apologize for the late response.
It might be possible that there is a DDOS attack. It is similar to the concern posted on the forum thread here.
These logs are similar to the logs that was posted on the old forum post here. The forum user 'WANAO' posted the solution he did wherein he changed the NTP settings and that solved the issue.
DaneA
- DaneAApr 16, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate hearing your feedback
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
