BigMoneyTK
Mar 27, 2018Aspirant
HTB: quantum of class 11024 is big. Losing internet
I have several loose internet connection intermittenly. The log shows this, HTB: quantum of class 11024 is big consider r2q change. Also could show 11024 instead of 10001 or both. I'm looking for a s...
- May 03, 2018
Hi! Thank's for solution.
I'm doing a follow up to see any more error so far, still watching this log :
Tue Apr 17 11:29:31 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (209 bytes)
Tue Apr 17 11:25:06 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (209 bytes)
Tue Apr 17 08:34:25 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (552 bytes)
Mon Apr 16 18:24:19 2018((GMT-0300)) [FVS336GV3][Kernel][KERNEL] xt_TCPMSS: bad length (324 bytes)As I have mentioned from my previous response, there might be possible that there is a DDOS attack. It is similar to the concern posted on the forum thread here. The logs states that the firewall received an improperly formatted TCP packet. It might be a hacker probing the firewall to see if it can breach the firewall's security. The firewall handles this correctly in which it discards the packet without any harm.
DaneA
NETGEAR Community Team
BigMoneyTK
Apr 17, 2018Aspirant
DaneA
May 03, 2018NETGEAR Employee Retired
DaneA
