VaderRocks
Oct 27, 2011Novice
Hub and Spoke to fully meshed VPN
Greetings, I have 4 locations using FVS338s in a hub and spoke VPN configuration. I want to change from hub and spoke to a fully connected VPN network topology. Is the FVS338 smart enough to perfom l...
adit
Oct 27, 2011Mentor
There is no LCR in an IPSec VPN. There is one route between the two endpoints (no matter if it is full mesh or hub & spoke).
Since you have a single WAN router (FVS338) you can only use a single ISP connection. You cannot do LCR.
I think you might be using the wrong term (LCR).
