VaderRocks
Oct 27, 2011Novice
Hub and Spoke to fully meshed VPN
Greetings, I have 4 locations using FVS338s in a hub and spoke VPN configuration. I want to change from hub and spoke to a fully connected VPN network topology. Is the FVS338 smart enough to perfom l...
adit
Oct 28, 2011Mentor
You use the same IKE policy and add VPN policies to it. One for each subnet, IP range, or individual IP that you want available between the sites.
You should be fine.
